+ Reply to Thread
Results 1 to 5 of 5
  1. #1
    Junior Member candyman13's Avatar
    Join Date
    May 2010
    Location
    lisle
    Posts
    16
    g body front end parts
    i have a stock g body front end with new ball joints, new calibers, new hoses, new pads. I also have the summit brand 3 way adj. front shocks never used and 2 sets of springs for the front, a pair of v6 springs and a set of v8 springs with one coil cut out, also have a set of stock rear springs. its all stock junk with new parts and fresh black paint if you need anything send me a pm any decent offer will work just want to make room in the garage. im also willing to part this stuff out. i also have a brand new strange master cylinder with a 1.032" bore which will work with stock style brakes.
  2. #2
    Senior Member NCRMotorsports's Avatar
    Join Date
    Jan 2005
    Location
    Bloomington Illinois
    Posts
    1,393
    how much for the master, and is there a mount for the firewall?
    1969 Camaro RS/SS X275 25.5 stock suspension
    360ci with a 88mm turbo
    180mph on radials? Why not....
  3. #3
    Chitown's #1 Hillbilly
    Join Date
    Sep 2004
    Location
    In the Garage!!
    Posts
    750
    Interested in front end parts 708-932-8702 Thanks Dan
    Anyone can dragrace try ramming shit!!!!
  4. #4
    Join Date
    May 2010
    Location
    lisle
    Posts
    16
    all messages responded to
  5. #5
    Join Date
    May 2010
    Location
    lisle
    Posts
    16
    just wanted to add some stuff to the add i also have a set of weld drag lites the fronts are 15x3.5 with a 2.5 bs and a gm and ford bolt pattern. the rears are 15x8 with a 3.5 bs and have been drilled for rim screws they also have a dual bolt pattern. 300.00 takes the set sold
    i also have a ati super damper brand new in the box for a pontiac the part number is 917710 they sell for 417 on summit-$300.00 sold
    a pontiac ram air 3 intake freshly painted pontiac blue 125.00 and a holley street dominater intake 75.00
    bop th-400 long tail shaft was in working order but its benn sitting for a couple years might need a rebuild 150.00
    hurst pro matic shifter 45.00
    the strange master listed above 60.00
    9 inch third member with 373 gears 28 spline limted slip diff. its a stock case i have 2 axels to go with it they fit stock gody width i belive there 31 and 33 inchs every things in good working order just moved up to 35 spline axels and a spool 200.00
    i would like to get rid of this stuff if you see somthing you want feel free to make an offer no trades please
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
